semi auto stalling when applying brake
gar1380
This should not do if your auto clutch in that system of MMT is working properly.
Is the gar in neutral when this happens?
If it was normal manual, i would say clutch is catching on the flywheel a bit, but if this was the case, car would creep by itself in 1st gear.
We need more info,
Sorted now , turned out that when the new clutch was fitted it wasn't reprogrammed
