Hybrid problems on Toyota Alphard
ZahirBaba
Hello all,
I have this code P1325, and now my car does not switch on to HYBRID mode.
Hi Zahir, if you ask the question on google the code P1325 points to ignition coil fault.
Moved to the Alphard club.
Not unless it's got a V6 😉 P1 codes are manufacturer specific assuming the op has made a type-o
DTC P3125 Inverter Malfunction
you will need a high end scan tool or Techstream to pull the actual codes
In that case then it looks as though you have an inverter malfunction as Bob suggested.
As above, you need to talk to the inverter to pull the actual specific trouble codes
  • 1 year later...
Hi, my name is nauchad I got toyota alphard hybrid nd I got some problems
My car doesn't go.more than 60km/h, pls how to deactivate 4wd,
is it stuck in 4wd ? You need to get the codes checked and the transfer box motor looked at
if you drive it in 4wd too much at high speed and/or rpm you will cause a lot of damage
