Lexus ls460 - Lost keyless remote
Gomc
I lost the only remote Keyless fob. Problem is the VIN number cannot be located in the usual locations. Lately, I ordered from BE FORWARD a set of ECU, ID Code unit, Smart Key unit, Receiver Assembly, Start Button and 2 keyless fobs. Replacing the ECU, Start Button and the Smart Key unit improved the situation where I'm now able to access the vehicle by proximity control. I'm also able to switch on the vehicle however the steering is still locked and I'm still unable to crank the engine. Two of those units, I still haven't replaced the Receiver Assembly and the ID Code unit because I cannot locate them. I've removed all rear including the rear seats and the front both sides, the A/C unit. I'm going to remove the centre console today.
Can anybody assist and advise please. Thanks.
Sent from my DRA-LX5 using Tapatalk
You would probably be best to look at the Lexus Owners Club - https://lexusownersclub.com
Hi Frost,
Yeah mate, Am also an active member of Lexus club. Did raise it for 6 months but no positive results.
9 minutes ago, Gomc said:
Hi Frost,
I'm just guessing you might be a Spanish speaker, so try this manual http://manualespurdy.cisdigital.com/Lexus/LS460L-LS460/rm2462s/MANUAL.HTM/rm2462s/index2.html
If it does not work, try one of those listed here http://manualespurdy.cisdigital.com/Lexus/  (just click trough until you get to index2.html files, that opens the manual)
Sorry no Spanish but thanks anyway.
