Spare wheel part number
WarChild007
I'm after a replacement spare wheel for my 2008 Corolla Verso SR, the current spare has a part number of 2170602, most wheels on eBay have a part number of 2170600.
It seems the 602 is still a 5 stud but has a smaller hole between two of the studs compared to the 600. Anyone know what this is for? Does it matter?
Does any one know the difference between the two parts? Is it the same spec but just one is a verso the other an avensis part number?
Edited by WarChild007
More detail
42611-0F090 or 42611-0F091 is listed for that year verso - 17 x 4, 5 x 114.3, ET39 a lot are listed in correctly as 5x110
Sorry, I'm not sure what that means?
You can see the differences here there is an extra hole in my wheel between two of the stud holes, at about 9 o'clock on the image.
iirc that is used on other cars that have a locating peg, it's something that toyota's dont use, tbh the rim its self is universal and will fit lots of cars
Locating peg example.
https://www.ebay.co.uk/p/1109669958
42611-0F090 or 42611-0F091  these are the toyota part numbers for the spacesaver spare wheel as used on the Auris
eg. https://www.ebay.co.uk/itm/TOYOTA-AURIS-17-INCH-SPACE-SAVER-SPARE-WHEEL-TYRE-T125-70D17-2170602/392689758616?hash=item5b6e223198:g:6Q0AAOSwEX1eSajj
Thanks for the information. So either the wheels, with or without the locating the will fit?
The ones with the locating hole seem to be more expensive for some reason.
