Usb/Aux
BillyGeddes
Hi all, I've bought a replacement dash for my mk1 aygo, the replacement one has the USB and aux in the little pocket under the heater box, is there a way I can wire this into my radio? I need to note that the wires have been cut so I'll need to wire it up too
TIA!
what radio do you have ?, i doubt you will be able to use it without an adapter (£50-80)
I've got a pioneer stereo in currently! It's got option for both USB and aux on the back of the stereo!
2 hours ago, flash22 said:
No it is out of the facelift mk1 its got a USB and aux in the pocket underneath the heater light area!
got it, usb is easy enough to figure out with a muiltimeter
dont forget a usb socket gives out 5V and NOT 12v
Ah okay, cheers guys, gonna try and play about it it and see if I can fit it to my stereo 😂 doubt I'm gonna be able to do it but worth a try!
It's easy enough, get a cheap usb lead and chop the plug off find some suitable pins (Dupont or JST) may do the trick and some hot glue to hold them into the socket
the same goes for the AUX in
if you can give me the measurements of the socket i will see if i can find something suitable if not i could do the mod for you
if you just want usb. https://www.ebay.co.uk/itm/USB-2-0-Flush-Mount-Socket-Extension-Cable-Port-Lead-Adaptor-Input-60cm-Car/370842903339?hash=item5657f5a32b:g:j3kAAOSwcx5ZZc-A
