Smart locking system
Amir-Naji
Hello,
The smart locking in My Corolla Hybrid stop working, and I couldn't find a reason why. I just wondering if anyone had an issue like that, or have any suggestions?
As the car should still be within the new car warranty, take it to a Toyota dealer to sort under warranty.
keyless start or do you have to hold the fob on the start button ?
That is my plan, but just wanted to see if there is something I can do! 😉
No, just the locking mechanism. It doesn't lock when I touch the handle of the door.
You mean when you press the unlock button on the key fob your car doesn't open?
The key was working, but not the touch for locking. The every other things were working.
13 hours ago, Malcster said:
Battery in the keyfob
Tried that as well, but that wasn't the issue.
I think I have found the issue. It seems one of the wires was a little bit loose, and after I re-attached again it started to work. I hope that was the issue!! 😁
Thanks for all the advice! 😉
