Reversing Camera Stopped Work...Guidance Appreciated
jvenables
Hi All,
Was on a trip last week, our holiday let was along an old private road, very very bumpy.. On Friday before we left the camera was flickering and now all we get is a black screen while in reverse more, the screen is working perfectly for everything else. So screen isn't the issue.. I assume it's a connector that's came loose. But I have no idea where to go from there.
Annoy thoughts on where I should check before taking to a garage?
Any guidance would be appreciated
i laughed at the title "guidance appreciated", is this because the camera isn't working and you need assistance reversing.
check the wiring loom in the tailgate as there will be a
connector for the camera, i doubt it would be at the
headunit end of the cable as the cable will terminate
in a multplug and if it where loose other things would be effected.
Eygo,
Lol, a bit of both re guidance....hehe.
Okay, sounds good, I assume that's the plastic cover inside boot behind the camera/registration plate...
I haven't worked on any cars before, it's held in with 2 plastic studs that I can see...is it just a case of popping the clips off with a screw driver?
hi john
i dont have an aygo so i cant tell you what fixings
there are for the tailgate panel ,but i'm sure
you will get some responses for other aygo owners.
