12v MP3 Sound Module
Biomecanoid
Hello,
I want an MP3 sound module with an sd-card slot and onboard speaker that would play a music file ( only once ) when you 1st apply power to it and if you keep the power on after the music file is done it will not do anything else.
Something similar to this :
https://www.amazon.com/gp/product/B0058M0TN8/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B0058M0TN8&linkCode=as2&tag=grimrepair02-20&linkId=1a186c9858aaaeb4b6522835f17fd645
https://www.ebay.co.uk/itm/WAV-MP3-Voice-Module-10W-Sound-Player-DC-12V-24V-Programmable-Control-Support/133525312086?hash=item1f16ba9256:g:CewAAOSwmQNfaGdi
Anybody knows where i can find one ?
Thank you
Chris
What is its purpose ? What sort of volume ? mono or stereo ? Does it have to be mp3, wav is more common, why does it need to stay powered on ?
https://www.ebay.co.uk/c/6016939403
use a relay or transistor to trigger it
or
http://www.icstation.com/voice-playback-module-hv20t-high-power-digital-amplifier-module-card-socket-mono-8ohm-uart-controller-arduino-p-14437.html
there are loads of modules about
or
Ideally it should have a speaker on its PCB, just a simple mono will do and loud enough to be able to be heard in the car. I don't mind if its not mp3 any sound file will do.
What i am trying to do is add a chime to the car that goes on when you turn the key and switch on the Battery.
I plan to tap 12v  power from a fuse. So the sound module will turn on with the car and will stay on until you power the car down so that's why i said the sound should play on ONCE and not be continuous, the sound should repeat only if you power cycle the car.
I have already found the module you showed me on eBay but that works on 5v which means i should add another hardware to convert 12v down to 5v which will make things a bit more complicated and more things can fail. The second link seems to be a module specific for Arduino.
If this little project is successful i will use the same technique to power and install a Dashcam.
