Auris - Clearing drainage holes/pathways
Kojac
Hoping for an education on where and how to clear all of the rain/water drainage holes on my Auris mk1.
Over time they get blocked/dirty & need to be cleared.
Need guidance in where they all are & how to do it competently.
Many thanks,
Kojac.
Rear lights , needs to be removed from the car, thoroughly cleaned, use new gaskets or silicone seal and put back on the car. On the front when raining and you inside the car should hear water flow through the body somewhere around windscreen passenger side, if you don’t hear that you will need to investigate further, possible removing of plastic surround windscreen and wiper arms. I haven’t had any issues so far on the front, only rear.
