Pre crash safety callibration 2016 avensis
George Leslie
Hi had new windscreen fitted by national windscreens all worked perfect no problem , this was Oct 2019
Now it's not working with permanent warning as soon as 10 mph achieved ,
Im in Nottingham, can anyone suggest a decent business that can do this work for me? Need it doing as the fault kicks out all the vehicle info on dash I normally rely on
Thanks everyone
Did national windscreens perform a calibration after fitting the new screen or just advise you need the camera calibrating? I work in a body shop and we use our local Toyota main dealer which is approx £200. You need to have a 4 wheel alignment done before calibration also 👍
