Previa Gs Stereo Wiring
Mad4it
Some advice please.
Have fitted aftermarket Head Unit to 98 Previa GS, but cannot find a permanent live in the wires. Ignition Only.
The result of this is that the memory presets do not work, and the clock on the roof lining keeps resetting itself.
Any ideas.
HI HAVE YOU EXAMINE IF ANY FUSES HAVE GONE FOR YOUR LIVE? ALSO IF YOU DO USE A DIRECT FEED FROM Battery DONT FORGET TO FIT A FUSE.
