Toyota Estima Hybrid - Full service kit / parts
Jam360
Hi All,
Does anyone know what parts need to be changed for a full service on a Toyota Estima Hybrid 2012?
The car was imported and seems to be running fine but fuel consumption is terrible.
On the console of the car, I think it shows 8.8KMh to the gallon.
I want to check what a full service consists of, assuming it's the usual suspects:
- engine oil
- oil filter
- fuel filter
- air filter
- gear box oil and filter
Greatfull for your advise.
Thanks,
J
Japan uses the US gallon rather than the Imperial (UK) gallon.
Your figure equates to 5.468mpg (US) or 6.57mpg (UK).
The best way to measure consumption is to go for a brim to brim calculation. Fill the tank to the first click on the pump, record your mileage, use the car, than when you need to refill, fill to the first click. Then calculate the consumption using how much fuel you've put in, against the distance travelled since the first fill. That will provide a more realistic idea of consumption.
