Fixed my distributor cap now my 1991 levin won't start..
1991 levin
Moved to Japanese imports
How did you fix it ? Did you replace the cap and rotor arm ? did you take the rotor arm off ? If so, did you clean it
any pictures of your rotor arm and cap ?
Where are you located ?
What engine ?
So I’m sorry I’m jacking this post but I have a 4efte swap In my paseo. Im installing a micro tech ecu. My goal is to convert to sequential ignition.  I have everything wired up. execept  Im not sure how to identify which wire is pickup wire?
