Roof rubber plastic line
John16
Hi
In my car the passenger roof rubber/plastic line is missing
Any ideas where i can buy it used pls?
Couldn't find it on eBay
Thanx!
See:
I just bought an Aygo and both sides were missing when I got the car.  Picked up both from a breakers for £30 for the pair.  The guy at the breakers told me to glue them in with superglue as they can come loose or get stolen. Buying 2nd hand I wanted to see the car they had come from.
A further thought if you are looking for these - the main dealer told me that they aren't 'handed' ie. interchangeable from left to right, however the ones I got from the breakers have L and R imprinted on them.  I haven't fitted mine yet due to the weather but they look like they might be slightly different for each side.  Maybe try and specify which side you need if you can.  They are £43 each inc VAT from the dealer btw.
Handy info, bit pricey from dealer for a plain strip of plastic, so good job breakers came to rescue. Quite a common problem on these cars, so keep an eye on ours, our 107s started lifting few years ago on back edge near tailgate, so glued them back on.
ordered the trim from my dealer, thanx !
as u can see theres some rust in the trim place …does painting it with Hammerite antirust can prevent the rust from going on ?
  • 4 weeks later...
hi again
any tips pls ?
whats the right way to connect the rubber strips , just place and click them ?
put some rtv or glue it in the corners ?
thanx
