Toyota Aygo 2006 - No Tachometer
Mastro
I own an Aygo 2006 and I plan on buying a tachometer since my car does not have one.
My question is, do Aygo models have a plug/connector for it? Which I can just plug to the tachometer and be done with? Or is that not a thing for all models?
The early UK spec cars should have the tacho plug/connector taped up under the speedo cowl. Easy enough to check so worth double checking, to remove speedo cowl, turn steering wheel full left remove screw then fully right remove screw and cowl just lifts off. Happy hunting.
