CarPlay with USB
Ziya Adnan
On 4/2/2023 at 2:51 PM, Ziya Adnan said:
Graham;
there is no need to be sarcastic. There could be a specific SD card as it includes CarPlay and I was asking a polite question. Please don not bother replying as it gets annoying.
No it's no sarcasm. 😉 Simply iPhone has no microSD slot.   So you should save your music files in internal iPhone memory.
On 5/12/2024 at 9:57 PM, MardyMarvin said:
Some where on one of these forums people have bought a device which enables you to turn a none wireless carplay toyota into a wireless carplay. If you bought this device and then a usb hub and plugged the device into the usb hub and also a music stick I am not sure if this would work or not.
Perhaps something for you to research about but it will depend if toyota car will support multiple devices on a single usb port. But something else to think about
https://www.amazon.co.uk/CarPlay-Wireless-Bluetooth-Mercedes-2017-2023-Apple/dp/B0BWD31MRT/ref=sr_1_4?dib=eyJ2IjoiMSJ9.JXF77UE8EXviCw8sHGKC3KA04cA9g9kvDOap0a2VhDSle9pOzDQfUDAs47j-GlcV4mp2xHHhZQER0uMpZ-QbeOvjdDllaFjdfWBmZUh0OX9mncpoIfzjIDfRiAriASWF15gHgom81h8ireeXM4pqyImA4OIfWyXVTyKp9jh47GQdakbMCt76aIKOWv4-1oAwaEWuPtLIuNvSgKqP09WYHBsaVs3H59_naGhFmfmLuNc.GPVGygTYuZg8OQ_RgTvScVQ_GJcnT8UE1ra2z1MaflY&dib_tag=se&keywords=wireless+carplay&qid=1715547080&sr=8-4
Am researching this.
will let you know results this week.
iPhone pre 15 yes. Iphones with usb connectors support external storage like usb and sd card readers ( including micro to sd converters)
16 hours ago, Paul john said:
Iphone pre 15 yes. Iphones with usb connectors support external storage like usb and sd card readers ( including micro to sd converters)
Ok but if you use the iPhone USB port to connect it to multimedia system to use Car Play I don't think you can use it at the same time also for a storage device.
You can if its wireless CarPlay or bluetooth on models post 22
OK
After investing in a USB splitter Hub and a USB Tri Hub (Pics Below) I have found the following - enjoy:
Car - Prius MY20 / Head Unit - MY19 / iPhone 14pro (CarPlay enabled) / Usb1 Samsung 2Gb / Usb3 Generic 4Gb / Usb2 Multi Card Adapter with 8Gb SD Card / All Usb / SD formatted Fat32 and contain mp3
Plug Either hub or Daisy chained with all USB and iPhone plugged in to a Mac or PC and it sees all devices, no drama.
Now here is where it gets interesting- Plugging into Car Usb... dot dot dot
1 - usb splitter with any usb combination - source list on head unit shows the Label of the Usb/SD card as source and plays.
2 - usb splitter with usb / iPhone or iPhone wifi unit plugged in - source plays from either source but iPhone sources are as an ipod and CarPlay does not initialise
3 - usb splitter with any usb combination and iPhone connected with bluetooth - 3 sources for music in Audio, all play.
4 - Usb Hub with 3 sources plugged in in any combination - head unit says TOO MANY USB
5 - Usb Hub plugged into usb splitter or Usb Splitter plugged into Usb hub - head unit says TOO MANY HUBS
6 - Usb Hub in 1/2/3 as above, same results.
Conclusion:
Certainly with the MY19 Head Unit and I would suspect the same result from a MY17 and MY15 units fitted to the 2016/2019 revisions of the MK4 Prius and since Toyota (Panasonic) apply the same logic to their head unit builds by generation I would think these results are cross model specific.
The Usb logic of the Head unit seems flawed in the fact that it cannot differentiate between protocols, so your choices are 2 Usb MAX plus (optional) bluetooth OR CarPlay/AA No bluetooth.
It feels a little like Gandalf vs the Balrog... Thou Shall not Pass.
