Auris 1.4D 2011, 100K. forcing the DPF regeneration?
jucole
Hi,  I've had a lot of issues with the DPF in the past;  it's been taken off and cleaned but that only lasted about 6 months,  for some reason it doesn't seem to want to auto-regenerate itself;  so i've been forcing a regen using a diagnostic tool, the sequence to force it is to initiate the regen, wait 3 secs, then switch the ignition off, then back on, then drive the car etc.  Can this regen be activated whilst the car is already in motion on a motorway? (obviously not by the driver!)
Regards
