Swapping a rear door tomorrow on my Daughter's 2006 Yaris
My Daughter has a Yaris
We've managed to source the same colour and trim from a breakers. It looks like just 5 bolts and electrical connector. Any top tips? I'm fairly handy with tools and DIY but have not done this before.
you will have to remove the door step trim and lower B pillar trim to disconnect the door wiring
Make sure you have an extra pair of hands available when needed.
yeah , I saw a YouTube video where they did this on a Camry I think, but I've looked at the electrics and there is a connector accessible from the outer side of the B pillar behind the rubber bung. This was the way I planned to connect it. is that not correct?
All done! Was fairly simple in the end. Thanks for the advice
