gti wheels 4x100
purewavy
2 hours ago, purewavy said:
Are the Corolla gti wheels 4x100 just like Hondas??
Toyota 4/100 54.1
Honda 4/100 56.1
Interestingly, the Mitsubishi i-MiEV electric car used 4/100 56.1 front rims and 4/100 54.1 rear rims.
This was so that the rear rims couldn't be fitted to the front unless the front 54.1mm to 56.1mm spigot was removed from the front hub.
4Jx15 ET35 4/100 56.1 front rims (from Mitsubishi i-MiEV)
ALCAR 4-Hole, 15Inch, 100mm, steel wheel Rim 7160 buy
https://www.autodoc.co.uk/alcar/14750574
5Jx15 ET35 4/100 54.1 rear rims (from Mitsubishi i-MiEV)
ALCAR 4-Hole, 15Inch, 100mm, steel wheel Rim 7235 buy
https://www.autodoc.co.uk/alcar/14750584
