Cold starting issues avensis 2.0d4d 2008 estate
viking500
I have starting issues with my avensis but only when left overnight
When it's warm it starts immediately with smooth running,bags of power. What could it be.
Glow plugs check if its receving a voltage if it is maybe time for new ones.
Sometimes it can help to repeat cold starting ie wait unto glow plug indicator goes out for a second time before starting.
I replaced the glow plugs last year and when it's warm I have no issues with starting. Just when it's left overnight and I've cranked it over up to fifteen times and still no joy . it's only when I get a jump start from another vehicle that it starts. I've go though the Battery and a booster and another Battery that I've previously charged up still. No joy perhaps.
If its starts ok from cold when hooked upto another car I be checking voltage when starting across Battery and dont forget engine earth and look out for corrosion on wiring earth ends.
Rememder you hooking upto a diffrent earth point when doing a jump start that why I am sugesting looking at the Battery earthing / nutral lead for corrosion.
Thx Derek, I will have a look at the earthing lead, see if there's any rust.
I'm
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
