DAB Antenna
kachel
 I want to replace my old antenna with an original DAB antenna, does anyone here have a description of it, how can I fix it?
it's a complete aerial and base, you will also need the change the wiring which involves pulling the top of the dash
kgb40 aerial_compressed.pdf
Hello, if I remove the panel from the A style, I will not have any problems with the airbag ?
the A pillar trims pop off with a trim tool they are just a cover, no issue with the side curtain air bags
to add the aerial you need the 2 cables the aerial base and the antenna
