Camry Axle
Rtime
I have a 2002 Camry with 14k miles. There is a problem with the right front axle. The dealer says he will replace both front axles but admits he is mystified why I have a problem. The car makes a grinding sound when I turn, also vibrates up steering column.
Should I be concerned that this happened? If axles are replaced, can I be confident the car will perform? And why is it taking two weeks to do the work?
