Need Help With Alloys For My Yaris!
rudeboy99x
can any1 tell me what are the largest size alloys i can put on my standard yaris. I want to order a set of 17's but arent sure whether they will fit. does anybody know??
youll need to roll the arches if youre thinking of getting 17s ..same if youre lowering or else Shell rub also make sure thay are 205 40 17 offset other than that no problems
yea but 17s without lowering looks horribe, sits soo high
16s u can lower fine, mines lowered 40mm on 16s and no problems
if u want 17s just be prepared that the arches will need to be rolled
i was wanting to put the 17" multi spoke alloys from the avensis on the new car- was getting a t-spirit but the choice of alloys are *****. Ended up with my lovely t-sport.
But make sure the wheels take 4 wheels nuts or it wont fit on the hub!
I use 17s here in ireland so it needs to be a bit higher as the roads here are crap really
I got 17" on standard suspension.. no rubbing at all.. PCD 4X100 ET 42 (offset)
