Bench Seats For Hilux
sticks
You have a single cab with two bucket seats now?
There are bench seats for the Hilux that will bolt right in. Just call around to some of your local wreckers and find a totalled Hilux base model and you can just pay 50 or whatever they want for it and bolt it into your Hilux.
I would look for the split bench, if you have a newer (last 5-10 years) Hilux then that is what would have gone in anyway. That way you can slide the driver half forward seperate from the passenger.
Thanks for the advice i do have 2 bucket seats at the moment and as the truck is 9 years old .
I assume the previous owner had changed the seating.
I did not want to part with it as it is also used for work logging and need the space of the bed for loads as opposed to the double cab.
It is still going well,dam near indistructable.
