Wheres This Wire Ment To Connect Too?
cookci
im guessing it used to be connected to the engine somewhere? The ring on the wire looks too big to connect to the Battery negative terminal
it was disconnected when i got the car... the other end goes to the chassis... u shud be able to follow the wire from the picture.
it either goes to the rocker cover or the gearbox if its long enough , seeing as its an import it may be different . :P
:lol:
cud use someone telling me exactly where it goes tho... ive had a scout round and cant see a point big enough for it :(
sorry but ive moved on from the 3sge , so i cant go out and have a look either.
Connect it to the house mains, and see what blows!! :P
Sorry, how useless was that? :ph34r:
its only an earth , put it somewhere on the engine or gearbox.
That cable is what you attach to the flux capacitor !    :D
It looks the same as the one on my GT4 which i just took off. Connects from the chassis to an M10 bolt at the top rear of the g/box casing just in front of the gear cables (I imagine its pretty much the same on your g/box. :thumbsup:
