3sgte Manifold Onto 3sge
em_ar_two
are the engines the same part from the turbo does anyone know, could you fit the turbo manifold from the 3sgte onto the 3sge
I would say more than likely...thinkin of a tubby conversion ?
you'll need an oil feed from the block, and lots more..its been listed on here before somewhere !!
Why bother ?
You'd need all new internals, a new ecu, injectors etc. etc. just buy a tubby lump ..
