Lambda Sensor For Toyota Paseo
mellow_yellow
Toyota!!!!
Be wary of the pattern part lambdas! although there is nothing wrong with the sensors themselves (they are just as good) the toyota style glange mounting kits are the problem... They fit right on, but as a result the sensor tip is often not totally in the gas flow....
Toyota ones cost more, but work better :thumbsup:
www.justlambda.co.uk
