Carina Ii Xl -> ?
Turbo16
Hi guys!
I have Carina XL -90 without cat.
I was wondering make Her a little devil.
How does 3SFE engine goes under the hood?
What changes i need to do?
Is there any better engine available to Carina II ?
What about turbo? I have one Mitsubishi TD05-12T in the garage available :).
Sorry,my bad english :censor:
Hi guys!
i dunno but it is really worth doing. the car is pretty old. to turbo a engine it would cost a fortune.
Hi guys!
why the 3sfe????
if u are going to change your engine, then consider putting in a decent one like the 3sge.
Hi guys!
why the 3sfe????
yup the 3sfe engine sucks ! i have one - i wish i had the 3sge put in now (170 bhp instead of 140)
If you put a turbo in your car, buy a 4A-GZE crankcase for the turbo engine base.
I bet it will be strong inaf for turbo base, because GZE engine is supercharged.
With un aspirated engines is also the the 4A-GE choice.. A-fe can stand 0,5 bar boost with out tuning. And if hunger grows, polish cylinder head, buy megasquirt -engine cortrolunit and lower cylinder pressures.
The 3S-FE/-GE swap is more difficult, because you have to change engine mounts, driving shafts, gearbox and electrics, so I thin it is way too much work to do :blink:
