Topping Up The Charge Cooler After Engine Light
Leeky
Had this same problem with my last st205.
I cant remember, do i park to car on a hill with the nose pointing up or the nose pointing down?
Think its pointing up but not 100% sure.
hmm, Mr T garages dont have hills, they just top them up on the level.
top it up with the engine running , is what i did , light went right off.
Yeah i used to top mine up on a level surface, but have since heard that a slight increase/decrease in angle allows you to get more in which makes it run more efficiently
Oh well...already topped it up, job done now :thumbsup:
When you top it up have the engine runnning, then blip the throttle, this will activate the cc pump and you will physically see the level drop. Top up while the pump is still running and put the cap back on. Job done.
If I remember correctly pump runs for about 30 seconds after throttle returns to closed.
  • 8 years later...
i just used this advice and it worked a treat thanks people
