Hosting Pics
kingdeacon
hi, does anyone know where is a good place to host my corolla gt pics? as i have quite alot now that i would like to store online for safe keeping and so i can share them with people that might want to see on here? one thats quite cheap would be good
thanks
which one of these can be used for sigs on this forum? or can they all?
thanks
rob
thanks
rob
Photobucket is very good..... Use that for all mine...and quite a few on here also use it... :thumbsup:
thanks
rob
They all can, but i use Photobucket :thumbsup:
thanks
rob
thanks people, doing it now
ive done it but think its a bit big, how can i make it smaller?
done it
what do you think of my car? its changed a little from that pic with roll cage, and no back seats carpets ect, plus full stainless zorst with 4" slash cut diagonal exit pipe
So where do your friend sit now? On the roof? :P
umm in the front seat round bands hatch if they are brave enough, or in my other car
when i get round to the wheels, which will be after ive finished my roll cage. I will be getting them polished as i think i want to keep the size as it is with these on it as they are the standard size which works very well with this car ToyoProxesR888185-60-14.jpg
If your after tyres, i've heard good things about Marangoni, only thing is they seem difficult to get hold of <_<
Look nice too :D
Marangoni (as far as i know) are made in Italy by Pirelli (not owned by Pirelli.. but manufactured by them under liceince). We used to sell them at work, not bad.. but there is better for the money, Marangoni's aren't cheap as far as budget range tyres go.
kingdeacon.. the tyre you have in your post.. (post 17#) are for off road use only by the loks of the tread pattern.. you won't pass an MOT with those on a car.. will grip like s*** to a blanket though.
Jones.. marangoni.tread.uk@marangoni.com should be able to tell you your nearest dealer.
What tyres would you recommend? a lot on here seem to like Toyo Proxes T1-R...
I had 195/50x15 Toyo's on the Yaris.. then got 17".. my boss wanted me to try Kumho's out (got them free) so now i run 205/40x17 Kumho 712's (the latest Kumho is KU31) I haven't notived much difference between then tbh.. but then, i don't race it... but the car does stick to the road very well.. as for mileage, so far so good.. getting good wear.
My 1st choice would be Toyo.. if they are slightly expensive for you.. i would reccomend Kumho as a good budget priced tyre.. they perform pretty well. :thumbsup:
1744_ss.jpg Kumho KU31
712.jpg Kumho 712
I had 195/50x15 Toyo's on the Yaris.. then got 17".. my boss wanted me tto try Kumho's out (got them free) so now i run 205/40x17 Kumho 712's (the latest Kumho is KU31) I haven't notived much difference between then tbh.. but then, i don't race it... but the car does stick to the road very well.. as for mileage, so far so good.. getting good wear.
I'm running on 195/45/16 Kumho KH11 at present, dont rate them that well really, in the wet they give up quite easily :(
I'll be after some tyres in a couple of months, so i think its between the Marangonis or Toyos, price isnt really that much of a problem as i'd rather pay another £10-£15 per tyre to have a good set that i know will grip well :thumbsup: :D
primacy.jpg Michelin Primacy
kh11.jpg Kumho kh11
I don't like michelin tyres.. i feel they let me down in the wet.. and as you can see from the pictures above.. the primacy and the KH11 have (more or less) an identicle tread pattern, maybe something in that.
If money isn't a problem.. then Toyo's are the best bet :thumbsup:
**back on topic**
they are road legal
Proxes R888 Specifications
Our new track day tyre is the road legal Proxes R888. Design by our motorsport team using high tech computer systems has resulted in an outstanding compound that delivers perfect results in the dry and wet. The medium soft compound has performed significantly better than soft compound competitor tyres.
if you look at the pic again you can see the 1.6mm limit bars as is needed now days on a road legal tyre.
more info and sizes on toyo's site which is where i got the specs from
