Lucida Fuse Box
NahiemAyub
I have a Toyota Lucida. The clock display has stopped working and the electric door mirrors have stopped working too as well as the cigarette lighter. I'm sure its a fuse that has blown, can somebody please tell me where exactly it is
Many Thanks
lift bonnet and check fuse box above Battery should be a 7.5 rated
mine kept going so i hard wired the lighter to the ignition to solve problem.
ray
lift bonnet and check fuse box above battery should be a 7.5 rated
ray
I have checked this 7.5A fuse in the bonnet (the only 7.5A) and it is not blown.
This problem arose after I fitted a CD player in my Lucida, however, the CD player works
  • 8 months later...
ray
It sounds like you pulled a cable off when you put the cd player in.
Many Thanks
send me your email i will send you hand book with all translation in english
the fuse box is under dashboard at passenger side, should be the second one from left in the second row, it is a 15a fuse, powered the clock, cig lighter, and power mirror.
wish this helps
wish this helps
sorry, it is third one from left. 15A
  • 2 years later...
Many Thanks
there is one under the passenger glove box but i have not checked to see where the other one is as ive been told there are two
any chance I could have a copy of that fusebox translation please, new to here and my windows and blow heater have just given up.
deanpwatson@gmail.com
many thanks
  • 2 years later...
can anyone give me a translation for both fuse box for my lucida 2.2 diesel seanw1973@hotmail.com
  • 10 years later...
  • 2 years later...
Hi there my dashboard lights are not turning on aswell as the radio and the heater in my van but there is a manual book here but the thing is it’s all in Japanese I wouldn’t even have a clue what fuse is leading to what part in my van 🙃🙃 can I please get some help
