Panel Air Filter
Tahiti200
Does anyone know if the airbox is the same on an EP82 as is on the EP91 normally aspirated Starlet?
I'm looking for a panel filter, and have found that will fit a Starlet 1.3 from 1989 onwards, but the bloke can't confirm it will fit the later EP91 (1998 model). Anyone know for sure?
Rob
well the turbo filter box is different... not too sure about the n/a because i thought the only 82 fitted with the 4efe was the gi?
Rich.
shows what I know about these models - I assumed the 1300 in the NASP Starlet SR would be the engine used in the EP82. It appears that was a 12v??
Thanks for your help though.
