Ae92 Corolla Gti Wheel Fitment
ae92gti
Hiya,
Just wondering what is the offset for the above and will Vauxhall or Ford wheels fit it??
Cheers.
PDC - 4x100
Offset - et 35 - et45
Bore - 54mm
Not sure what year your car is.. but the above fitment is for '85 - '01
Other cars with the same fitment.....
Toyota:
Corolla, MKI MR2, Paseo, Starlet, Yaris
Mazda:
121 (pre-'95), 323, Demio, MX3, MX5
Suzuki:
Baleno
Daihatsu:
Sirion
Ford and Vauxhaul WON'T fit.
Vauxhall WILL fit, they are 4x100 but have a much smaller offset usually 42 or 45,'Rollas need 37/38 depending on what size of wheel you want, so with a set of spacers u can put vaux wheels on a 'Rolla. but Ford def wont fit, they are 4x108
Vauxhaul Bore - 56.6mm (some are 56.1 but i think these are 5 stud)
Offset - 37 to 45
Toyota Bore - 54mm
Toyota offset - 35 - 45
Vauxhaul's would need a centralising ring for PROPER fitment as the bore hole is 2.6mm bigger :rolleyes:
