Found Free Import Toyota Fault Codes
ben-T
Hi All
I have a problem with my 95 Toyota Camry. The Check Light is on the dash, so I had a look around the web for info on how to read the codes.
Came across this site www.auto-diagnostic-codes.com
Has FREE code info on Engines, ABS, Auto Trans, Airbags.... for cars from US, Europe, Australia and Japanese and Korean vehicles.
I was able to follow the instructions to read my engine codes, and then type the code in the system.
Code came up as code 12: Engine speed signal (NE), no signal to Electronic Control Unit (ECU) / CKP/CMP sensor.
Can any help me to know if this code is correct? Thanks!! :D
Hi All
Hi, what engine do you have in your car?
