Anyone Installed A Fse Boost Valve?
jabran200
hi gues wondering if any of you guys installed an fse boost valve on the 1.6 4afe avensis?
thanks guys, any help will be much appreciated
What setup are you running as these fuel pressure regulators are normally used for increased fueling for turbo's or larger injectors?
if it will fit you will notice it being there never mind the turbo, but on the 1.8 avensis the regulater is bilt in to the pety tank and thats why i have not put one on mine.
