Distributor For Gti Needed!
vanillaice
cant you buy 1 from a normal spares place, i bought 1 from from Nyanza in coventry, oscotts here also sell it
Are you talking about the cap or the distributor itself? I'm talking about the distributor.
If you are too, are new ones expensive?
Cheers,
ICE
Cheers,
ICE
Hell they aint cheap.. £268.56+vat 19100-16250..
BoB
Cheers,
ICE
BoB
Hell they aint cheap!!!
Might have sourced one locally for £50.
Thanks for the price tho BoB.
I'll let you know how I get on!
ICE
Different distributor didn't help - unless it's a duff aswell, but i doubt it.
What else could be causing the firing to be all over the place? It's as if the rev limiter has been set to 1000rpm. As soon as you rev the engine stalls? :ffs:
Cheers,
ICE
Check HT leads, coil, map sensor to start with.
Ht leads are magnecor and were replaced around Nov '05 so I doubt they are at fault.
I'm trying to locate a coil.
Not sure what to do about the MAP sensor at the moment.
Cheers,
ICE
coud be a dodgy connection on the dizzy as this is where the ecu gets it reference from for crank position. inspect all the wiring round the plug as they can go brittle
Cheers matey, i'll give it a try.
ICE
BUMP
I just spoke to fensport (been waiting for Gold card beofre buying a second hand coil and map sensor from them) and they doubt that its the coil.
They suggest that I get it to a garage that can read the fault codes, or even my local dealer.
Thats sounds expensive! :o Should it be?
Cheers,
ICE
is it a 4age i have spares if required
u can get a fault finder on eBay for £15 at least then u can check it yourself
u can get a fault finder on ebay for £15 at least then u can check it yourself
Cheers sparco_blues,
Have just bought one off eBay - hope it works!
I'll let you know if I need spares.
Cheers,
ICE
IT'S ALIVE!
Fault tester brought up 3 errors! Ignition, Air temp and MAP.
Did a bit of poking around under the bonnet and a wire into the MAP sensor had snapped (fatigued I guess). Had to cut all 3 wire and replaced the ends with crimp on connectors. Took it for a blast and all seems in order. Will try and make the repair more permanent at a later date.
When I get it home I will look into the other 2 errors, hopefully they are just knock on's from the MAP.
Thanks for all the advice lads, you've been much more helpful than Fensport :censor:
Cheers,
ICE
exellent news dude. i have seen this type of fault beforeand they can be very hard to find. glad shes sorted. send me a pic of the plug in question (detailed if poss) and ill see if i have a spare on some old looms i have. toyota tend to use generic plugs so there is a fair chance
Cheers matey. I think I will need to do something more permanent as when I got home (7 mile trip) I checked the new connectors I'd put on, they'd started to work themselves loose again. I don't think it's a major problem, but will need looking into for the long term. I will try and PM you details and pictures of the plug over the weekend.
Sure felt good driving her again :thumbsup:
Thanks again.
Cheers,
ICE
