Short Throw Shifter
Tercel GTS - DirtWeed
at the suggestion of a member on another auto forum I removed my shifter, moved the ball on the shifter as far up as the factory had machined clearance for, then removed a few inches from the handle itself, purchased a universal knob and the result has a touch over 2" throw from 1st gear to 2nd. Going into 5th requires a touch of effort thanks to the leverage change but downshifting from 5th to 3rd is a snap. I'm very satisfied with the results and recommend it to others. Save the money of buying one, it's too easy to modify your own
