Greddy Profec E-01 Boost Controller
EarL
Greddy Profec e-01 Electronic boost controller
Used for around 6 months. No longer needed, as the MoTeC is controlling the boost.
http://www.thor-racing.co.uk/GReddy_Profec...-GDY__PFE01.asp
GReddy's new super multi-tasker is the PRofec e-01 designed as a combination boost-controller, data display / logger and e-manage programmer. The e-01 can provide superior boost response, increased boost, warning meter functions, 3 channel data-logging and access to all the programming features provided with the latest e-manage support tool. Even when used as a boost controller only, the e-01 has features to smooth out the boost curve. With both an auto and manual setting for both external and actuator style wastegates, the new PRofec can alter its new compact, high capacity solenoid valve via various RPM ranges. The large LCD screen with green electro-luminescent backlighting is easy to see. Other standard features include two preset boost levels, a timed over-take boost. The data display can view 3 different data channels simultaneously such as boost, RPM or any other channel input by the e-manage. The data can be logged up for 3 hours on an SD card while also giving warning set points and peak and hold values.
Normally retails for over £450!!
£250 + Delivery
EarL.
