Steering, Aircon, Instruments And Window Failure Help!
garcor195
Hello all,
after the last post (Power steering failure) I tried the switching on and off the ignition, but had no improvement.
I have lost use of the Power steering, dash instruments, Air con and heater controls and the electric windows.
Is there a master fuse anywhere or does the relay for the power steering control all these as well? the engine cooling fans run once the ignition is switched on and do not turn off.
The car will start and drive but none of the above work.
It will be a few weeks before I can get the car to a garage so any suggestions or help would be greatly appreciated. :help:
Thanks again for your time and help
Gary :thumbsup:
Had a look at the wiring diagrams and its probably the 'gauge' fuse, that seems to be involved in everything that's not working anyway!
In the fusebox in the driver's footwell apparently :)
the old Gauge fuse failure eh?
I will have a look, am due a few days off so will check it out then.
thanks again for your help :thumbsup:
I will let youkknow how i get on.
Gary
Cool :)
At least you don't seem to have anything that's just making the fuse blow again straight away, tracking down a leccy fault in all that lot would be a nightmare ;)
