Camry Performance
camryboy
Hey everyone, its my first post,
i have a 1994 toyota camry, without any major modifications (stock here :P ) what can i do to get the most acceleration out of it? its an automatic, i know the ECT kicks up the RPM 1000x, but what about the overdrive setting, starting in drive or starting in low gear and the shifting it up to drive, starting in N and reving before shifting into D, you know, cheap stuff like that to get off the line quicker and making my camry a little more fun B)
what do you guys do to get the most out of your car?
thanks
  • 3 months later...
dont sell it....get urself a Toyota ct26 turbo, a 3sgte ex. manifold, a 2-bar map sensor, sum supra injectors, and a couple other miscellaneous parts and turbo that camry out, and then go bust some *****.
luisitol has the right idea and N revit an drop to L is good. computer chips help and intakes and exoust will help. also suspention to keep the car planted for better grip off the line.
