Door Speakers Not Working / Remote Locking / Armrest?
davidcraig2003
Hi There.
Recently bought a 2004 Toyota Yaris (Im only 17 - first car! =] ) The two door Speakers wernt working. I got it from a dealership, who cut a bit off as a result, although said they hadnt looked into the problem. The two dash Speakers are fine, so i was wondering if anyone else has had this problem/a solution that saves me buying new Speakers.
I noticed theres a balance option on the controls, however, only to select betweem left/right speakers, i couldnt find a fade option to select between the front/rear speakers.
Any help would be greatly appeciated.
Im also looking into having central locking installed, along with an armrest. Just wondering if anyone could recommend any.
Thanks a lot :thumbsup:
Dave
I'm afraid to tell you in a standard T2 you don't have door Speakers! Only 2 dash ones as bottom spec :) Better off looking for a set of aftermarket ones which if you search on this site you will find lots of information about fitment :thumbsup: Arm rest wise i'm not sure and central locking kits all depend if you have a good auto electrician to hand. If not standard toyota one worth looking for on eBay!
Welcome to the club!
Hi There.
Recently bought a 2004 Toyota Yaris (Im only 17 - first car! =] ) The two door speakers wernt working. I got it from a dealership, who cut a bit off as a result, although said they hadnt looked into the problem. The two dash speakers are fine, so i was wondering if anyone else has had this problem/a solution that saves me buying new speakers.
Dave
I would be a bit wary of a dealerthat didnt know the speaker layout.Another yts salesman?
It is a T2, although has a Toyota CD Player installed at the bottom of the dash =]
Theres certinally two Speakers on the door, or at least, two openings on the door panelling?
