stereo removal
RichGT
Do the following:
Remove the gear knob..
Remove the gear sround, just clips on.
just under the lighter section there are 2 screws, remove them
Rest of the sround is one piece, cearfully remove it, it is also clip on jobby. dont use any sharp objects
Stereo is mounted on a bracket with 4 screws. may be 5 sometimes, remove the bracket
and stereo can be taken on the bracket.
  • 1 year later...
I know the topic is old, but I have a question that relates to it:)
I've just bought a new Pioneer head unit for my 96 Celi GT, I have all the necessary conversion cables etc, however one thing I don't have is a replacement facia. I can find ones for older pre 94 Celicas, and indeed the latest model, but zip all for mine. Even caraudio direct couldn't help, although they suggested the 83 - 94 facia set they have *may* fit.
Any ideas as to where I can get one, as I don't particularly want a gaping hole where the slot CD player used to sit under the old casette/radio head unit.
Also if anyone is having problems installing a replacement set of Speakers in a 94 -98 Celica, let me know, as I'll be uploading a small guide and a few piccies on how to do it onto my webserver when I get a mo - well it's the way I did it anyway!:)
if it had the double din unit fitted you can buy the black box that was on 94- 95 celicas and gen 5's , which screws onto the side of the new head unit , they cost somewhere near £ 40 , also no need need to remove gear knob and surround , simply push it to 1 side to gain access to those 2 screws.
Dunno if it makes a difference, but the Toyota stereo currently installed is actually 2 single DIN units, a Cassette/radio on top, and a single disk CD player underneath, which according to my owners manual was an optional extra. Would the double Din facia you mentioned still be appropriate? If so, any ideas where I can get one
if you just want a single cd player as i have , its 2 silver brackets which attatch to the side of the single din , with a black box with the word TOYOTA embossed onto it , this hides the lower hole. :thumbsup:
go here download the pdf file i know its an older model but its pretty much the same.the box they use is flat . the 1 you get from toyota has the toyota logo on it.
http://www.installdr.com/InstallDocs/Toyota/Celica.html
You can also try autoleads. I got a cubby hole adaptor from them for about 14 quid. :D
also on the gen6 the small oblong facia that clips around the head unit itself dont fit most - due to the hole being so small .i had to leave mine off on a sony explode mp3.
I've just had the same problem when installing a Kenwood stereo in my '95 gen 6. Autoleads sell a pocket kit FP-11-01 which you can get from most large audio specialists, it costs about £25-£30. I also contacted Toyota and they had a pocket that was only £12-60 T55521-16030.
Obviously I got the one from Toyota and it fitted straight in. The only thing I had to do was trim the fascia of my Kenwood in order for it to fit.
Hope this helps
Tony
Thanks everyone,
especially Mr Stixx for providing the link to that install guide - I was quite worried that my car has the seperate amp, and that would cause me a major headache - the guide has put these fears nicely to rest:)
All I need now is to buy that facia! :))
went to that link, i got a double one too, cd on bottom,
never realised it looked so much hassle to replace it
has anyone done it? gen 5?
it looks though easy enough with a bit of time and effort
Replaced mine with a single din unit. Got a cubby hole adapter from autoleads. No real problems. Took about an hour. :thumbsup:
have to agree its an easy job :thumbsup:
