95 Avelon Door panel removal Points?
jbates
I am looking to remove all of the door panels on my 95 Toyota Avelon to replace the Speakers and want to know where the removal pins are, better yet if someone has some removal instructions overall. Thanks!!!!
Jeff
Don't know how much this'll help, I've yet to try it out as it is just too cold to do anything right now.
1. Remove screw cap on door handle
2. Remove all screws from bottom of door, and the screw in the door handle
3. Poke the little knob-looking things on the right side of the door panel in with a screwdriver, and then pop them out with your fingernail
4. Slide the door panel up, it should come off with a little force.
Hope that helps.
