Well It Finally Happened
sphinktar1988
after 115,000 miles my clutch has started to slip :(
only in 3rd/4th and 5th at low revs but its anoying
anyone changed a clutch on a yaris before?
how much was the part and how much labour should i expect to pay?
any good after market clutches for the 1.3 sr?
Thats not bad my friends clutch went after 55k on his punto
If you paid full wack it would be £400 fitted
Get a decent aftermarket one (The lady on here with supercharged T sport has decent after market clutch)
Should be no more than £150 and fit it yourself buddy!
ah i see is fittin it hard or not? might get someone who no wat there doin to do it n not rip me off
should last abit longer but its jst gettin tempermental now :(
ah well not bad 115,000 k
dad got 160,000 outta his volvos clutch :|
so t sport clutch will fit ma car?
Clutch is pretty hard mate as you gota remove the gearbox! That means first moving all the crud above it to get to it then a crane to be able to support it while you work on it! not that easy then :P
earpl has some mad uprated clutch too and he says when he changes gears his whole dash moves! :lol:
Thats the name!
I would rather inlist a knowledgeable friends help and fit it myself than get ripped off!
True but its not THAT easy! Would be good if you got mate who works in garage that could help you :thumbsup:
Yeah i might even reach into my pockets and buy him a beer if he helped lol
ah well if it gets anyworst ill get the unibond no nails and glue the plates together :P
have an automatic yaris that stalls alot :)
so if i just got a t-sport clutch off eBay it will straght fit?
OMG asked an independant garage they said get the clutch and we will fit it for £345 :o
this is not good
and
ive jst flooded my house :|
this is not good
and
who have you got that quote from??
there is a place on albert hill called ST Johns he use to be the main mechanic for Toyota untill he opened his own garage.
i use to take my IS200 there and always had no problem from him he has also done some work on my TS too.
drop me a message and i will give you his number
My clutch cost around £300 and that was trade price.
as for the fitting i had Ian one of the techy's at work [ who had never done one on a yaris before]
to do it, took less than 2 hours 30mins to do.
If it takes a normal garage 3 hours to do, should be less than £200 labour.
if i was you i'd go with a direct replacement clutch, you dont need a performance clutch
esp if you got the mileage you did out of yours.
i might go for the performance one as i drive the car a lot harder than the previous owners as they were OAP's lol
also gettin a few performance mods of the car manifold, exhaust, sports cat n id like to no i could abuse the clutch if needed lol
as with my clutch now if i so much as frown at the car it nacks up for a few days then stops slipping :S
