Front Toyota Badge
Jp-Auris
i want to spray the inner bit of the Badge red, jst to make it look different, i was thinking of jst spraying it and cover around the Badge with newspaper but if it can be taken off then i would rather do that
I dont know if its possible as Ive not looked too close at it, but tooth floss is usually the way to go to cut the glue behind the Badge. It should then pull off......but.... having just looked at a picture is the Badge recessed in the front grill? If so it may be harder.
