Help
shadey
my glanza idles fine but when taking of in first and second it will misfire. after a mile or so the enginge management light will come on. i have replaced the plugs and leads but to no change, ne suggestions???? :help:
you need to interrogate the ECU to get the fault code that is registered when the warning light is triggered. This will tell you what is giving trouble and you can then work out what is needed to replace it.
Instructions on my forum under technical library section, stickied as Diagnostics Test.
Post the error codes here if you need further help.
Tools required, one bent metal paperclip.
