Project Toyota Vista 98 (camry)
bazz_f1
hello every one. i am quite new here and so as modification. i do have a toyota Vista 1998.
It had a 3S-FE engine. But recently i changed my engine to 3S-GE. I do have have a plan by the time i finish this project i want to put 400 BHP at the wheel. So guys i need your help and suggestion that i can finish my project perfectly.
i could not got ECU with my 3SGE engine but my mechanic already put [3SG A140E] ECU in. But i want to replace this with the perfect ECU [A241E]
Please guys let me know if it fine with the ECU already in or i should change it to the proper one.
You want to put 400 horseys through the front wheels??
Be virtually undrivable wouldn't it?? Wouldn't have thought you would be able to do that with a standard ecu mind. Your going to need one that can be fully re-mapped.
D*MN.... just noticed this thread is over 2 months old...... sorry!
