Centre Caps
ee9kid
After centre caps for my 2000 Avensis CDX
Ive got a load at home, could you measure them so I can make sure they are the right size. Going cheep as chips
Is it just avensis ones u have or have u others 2?
I notice you have a Prius too, if you take the plastic trim off your wheel, do your caps fit the alloys? If so, I'll have a set.
Just mainly Avensis alloy wheel ones, i think they are 52 mm but measure yours and I'll match them. Any pictures would be good
This is my Prius wheel, 52/53mm dia hole as best as I can measure it. Will your caps fit d'ya think?
  • 7 months later...
A Toyota dealer should be able to provide them. I got centre caps for my Corolla for a couple of quid.
