Gen 7 140 Recon Eng - White Smoke?
pacco212
Hi Can anyone help me out with the reason of white smoke coming from exhaust, I have just had mechanic change out the original engine that had an overheated head, we have replace many new parts like the thermo and usual new oils, plugs etc
On start up the car it is still emmitting white smoke after a few mins? We have checked hoses etc but cannot seem to get a detailed diagram of where the coolant hoses and air hoses should go, though the mechanic is 99% sure these are on the right locations.
The AC radiator was damaged and we have left this off? Would this make a difference?
Hope someone can help! I have run out of cash and just want my car back runing!!!! Cant afford the dealer prices to fix.
Check the brake fluid. When the servo goes it sucks brake fluid through the engine and it burns as white smoke.
Hi
Thanks I shall try that tomorrow?
