New Head Unit - Jvc Kw-Xr811
elgicko
Hi All,
I have a 2005 1.4 D4D 5 door hatchback. My original head unit stopped working recently (Model No: W58814). I got a replacement unit from the breakers yard (different model No), but I have lost the following:
Time.
Temperature.
Multi Function Steering Wheel Control.
I suspect the replacement part comes from a basic model, but I am no expert.
I am thinking of changing the head unit to this:
http://tinyurl.com/cy8koey
My questions are:
Will this facia panel work with this unit?
http://tinyurl.com/cntchh2
Do I need a steering wheel stalk to make the multi function seering wheel work, if so is this what I need?
http://tinyurl.com/d3zcgtl
Do I also need a patch lead!
Any help appreciated!
Steve
Hi Steve,
I swapped my oem unit and got a JVC KW AVX740. The Facia adapter I got was this one - http://www.ebay.co.uk/itm/CT23TY07-Toyota-Corolla-Double-Din-Facia-Adaptor-Kits-/400259130677?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d314da535
The above Facia will be a tight fit but my unit fitted perfect. Some Facia's need trimming abit for the unit to fit but I have a JVC so should be the same fit! (The Facia adapter from Dynamic Sounds Ltd did not fit mine!!!).
The steering controls should work with yours as it's a 2005 model. Yeah you will need a stalk adapter/patch lead for it. :)
Thanks GazzyG,
Do you have have steering wheel controls in your car and if so are they working? with this unit
Steve
I do have the patch lead/stalk adapter for the steering wheel controls but the controls dont work. They only work with facelift corolla's I found out after alot of searching because the plugs from the dash are different.
Hi Steve,
Sorry @ topicstarter to use this topic, but have you got a picture of the perfect fitting fascia please? :P
Because mine is crap, and I'm searching a good one :lol:
Grtz
Thanks for the picture(s) man.
Looks alot better than the fascia I got.
Here a pic of mine, and the arrows show the spots where it's not fitting.
Got big gaps, at the top, the frame is 4mm "deeper", etc :P
Edit: here 2 extra pics to show the difference in the upper corners:
Grtz
Thanks GazzyG for posting the Pic, nice job!!
I have ordered all the stuff, Ill post pic when its installed and report back on the functionality of the Steering Wheel buttons
Steve
